  • 1994 - 1995 Specific Tech
95 Gt, B303 With Timing Problem
  • Thread starter Thread starter another5.slow
  • Start date Start date Sep 20, 2012
A
another5.slow
  • Sep 20, 2012
I have a 95 gt that has a problem and i think its timing related. If i drive the car everyday its fine, but if i dont i can get in it to start it and acts hard to crank and it wont start like its out of time. I can advance the timing about 10 degrees or so and it will fire right up then i can reset to 12 btdc and its fine. I purchased the car about a year ago not running so when i put it back together i thru a B303 cam in it for the sound . Its been doing this eversince i got it running so i dont know if i was doing it before i bought it. I use to unhook the battery overnight and that would work too til i figured out retiming it. Im thinking the pcm is locking up or something and unhooking the battery is killing the keep alive memory in the pcm. Anybody had this happen to them? I did read that the pcm in the sl95 was sensitive to aftermarket cams.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 20, 2012
  • Sep 20, 2012
Welcome to Stangnet,
Did you remove the spout before timing?? The spout isn't missing right?
A
another5.slow
  • Sep 20, 2012
When i initially set the timing i did remove the spout and reinstalled it after it was set. When ever i adjust the timing to get it started i dont remove it. I put a mark on the dist and block where to set it back to. Pretty strange aint it?
toyman
1,944
54
79
Vernon BC
Sep 20, 2012
  • Sep 20, 2012
I'm going to guess that the PIP signal to the PCM is erratic or a worn distributor drive gear. I would opt for a new distributor (Richporter) or replace the PIP and gear if you have the tools.
A
another5.slow
  • Sep 21, 2012
Yea, thats probably a good place to start. I thought it was pretty strange though that i can disconnect the battery over night and the car will crank like its supposed to. Keep in mind it only does it if it sits a day without being started, you know like if I park it on Friday and dont try to drive it again til Sunday. I may put a stator in it over the weekend and see what the drive gear looks like. Thanks for the input.
Keith
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
