  • 1994 - 1995 Specific Tech
95 GT Fuel Lines
  • Thread starter Thread starter oleydd970
  • Start date Start date Oct 14, 2006
oleydd970
41
Miamisburg, Ohio
Oct 14, 2006
  • Oct 14, 2006
Does anybody know of an AN fuel line set that goes from the hard steel lines in the engine compartment to aftermarket fuel rails. Basicly what i really need is the fitting on the fuel line side, that has little plastic removeable clip, to an AN type fitting. I need both supply and return lines as they are different sizes. My fuel rails have a NPT fitting so converting it to AN is simple. The line sets for 87-93 are different, they are the push to lock type. Anybody with a solution for my problem would be gratefully appreciated.
parchisi
519
New Mexico
Oct 14, 2006
  • Oct 14, 2006
I tried hard to find the same thing when hooking up my fuel lines, but to no avail. You can get some kind of end that you can connect to the metal lines where you have to flange the ends of the line, but I ended up just running all new lines from the tank.
mootang
907
texas
Oct 15, 2006
  • Oct 15, 2006
the bbk rail kit will hook up to your stock lines. other than that i don't know.
oleydd970
41
Miamisburg, Ohio
Oct 15, 2006
  • Oct 15, 2006
yeah, I've been lookling real hard too. I cant find anything. Any idea on the price for running new lines from the tank. Aeromotive wants like $1500, anybody kmow of cheaper solution?
parchisi
519
New Mexico
Oct 16, 2006
  • Oct 16, 2006
Just buy some 8an feed line, and 6 an return line. I wasn't sure how to hook up the lines to the lines coming from the fuel pump. so I cut the braided part from the fuel pump and used some hose ends and adapters to hook up the new lines. It worked for a while but then realized it was leaking fuel, so I had to end up using a crimp on the end of that feed line from the pump.
sewngo
Orlando,FL
Dec 14, 2006
  • Dec 14, 2006
Russel makes a part to go from 5/16 hard line connector (near shock tower ) to -6an fitting.No fitting for the smaller 1/4 return line.
F
SOLD 94-95 GT Fuel Rails and Fuel Lines and Regulator.
  • fasterthangas
  • May 10, 2025
  • Engine and Power Adder Parts
Engine and Power Adder Parts May 27, 2025
fasterthangas
F
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • dan50
  • Jul 18, 2026
dan50
