Yep, they will be fine besides the 45 watts is only peak power right so that means it probably pushes more like 22-24 watts RMS(means continuous) the factorys will be fine. I'm pretty sure they are all the same I had a adapter in my dads truck hooked up to a clarion and put it in the stang, plugged right in and played with the mach 460 I have (the truck was a 97 F 150)Crock said:Cool... so the sony 45watts per channel will be ok going into the factory amps?
Also is it the regular ford harness or is it a certain 460 harness than I need to get?
