  • 1994 - 1995 Specific Tech
95 Ignition Coil Test Spec .
  • Thread starter Thread starter sore
  • Start date Start date Nov 12, 2006
sore
43
Lumberton,TX/Kenner,Louisiana (Home Town)
Nov 12, 2006
  • Nov 12, 2006
The other day my car just killed. It seems that the coil is the problem, but i just wondering if anyone knows what Ohm readings i should be getting when i check the coil?
Thanks,
sore
43
Nov 12, 2006
  • Nov 12, 2006
I know how to check the primary winding and secondary winding, but i don't know if my readings are falling within the specified range.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Nov 12, 2006
  • Nov 12, 2006
Have you pulled codes yet? For some reason alot of peoples PIP's are going out, including mine, When it went out the coil was getting fire, but not sending anything out.
HISSIN50
34
129
Nov 13, 2006
  • Nov 13, 2006
I'd have to check the book myself.
For a quick road-side test (when it breaks down - I'm all about quick and dirty test methods), put a test light across the two coil wires (the wiring connector wires in the grey connector, not the spark-plug-like wire) and have someone crank the engine over. See if your test light flashes while cranking. If not, the coil is missing key-on 12 volts or the ground pulse from the TFI. Go from there.
Good luck.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
9
1995 5.0 just cranks
  • 9GT5
  • Jun 29, 2025
1994 - 1995 Specific Tech Jun 29, 2025
AeroCoupe
D
How to test for a bad coil pack - 4.6 liter motor
  • DesertStang
  • Oct 7, 2025
2K
1996 - 2004 SN95 Mustang -General/Talk- Jan 14, 2026
DesertStang
D
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
