Anyone know if its possible that if the MAF's Wiring is not correct if it will cause the Starter to not even be allowed to turn over? I Highly doubt this but what im facing is I just purchased a Calibrated MAF for my new Motor build up's Injector sizes and the MAF was on a 93 even tho the Markings for the (A,B,C,D) Positions to the Cable Harness were Identical it seems I cannot get the car to even turn over at the moment. Had the Starter Checked at a local Autozone and it checks out fine. Also my Clutch Saftey Switch I Checked for voltage when key was in the Start Position and I get the 12v down there Also Replaced the Starter Relay. The only thing I did also Attempt (because for how much of a pain in the rear end it is to replace the clutch safetey switch) I Jumped the wires directly across bridging it and basically removing the saftey switch so I know its none of the above. The only thing really left is the Ignition But what I dont get is that I do get the correct voltage at the Clutch Saftey Switch and the Injectors, Fuel Pump, ect Kick on When you turn the key to the Run position. If nobody know's for sure then I will just have to get out the good old Ohm meter and check the Ignition Switch. Just really sucks.
