95 overheating
newe
9
Have a 95 mustand coupe V6, 5 speed that is overheating, or so I think.
Shoots up to the red line instantly, erratically. Changed the thermostat
to 160, changed water pump (autozone special), and also changed the
temp switch. Set the fan to run direct, bled the air. There is no water
in the oil, and no leaks. What else is there? Can anyboy out there help?
At one point when the gauge was reading at the red line, I touched the
upper hose and radiator...... not even hot. I dont know....
You said "temp. switch" mounted on the block right? U can check the reference voltage at the engine temp. sensor with a multi-meter it should be less than 1 volt (I think) if that’s good then I would change the engine temp gauge that is probably stuck with the whole cluster speedo/tach/fuel. Thats what I would do, hope that helped.
If the needle jumps instantly, it's not a valid reading from the sensor- it's a shorted or broken wire. If you already changed the sensor, the problem is with the gauge or somewhere along the harness.
Start the car and turn the heater on. After idling for awhile, the heater should start blowing warm air, and shortly after that, the upper heater hose should become warm (thermostat has opened). If that happens normally and the coolant doesn't boil over, your problem is an indication issue for sure, not actual overheating.
