The Cosed Loop part or cruise around town part of your tune is being constantly monitored and controlled by various sensers such as O2's, ECT, ACT, etc.
The adaptive strategy system can and will take those various inputs and + or - spark or fuel.
In a perfect world situation, you would change all values from original to exactly the values your particular combo needs or in other words, a custom tune for your Stang and your Stang only.
If your efforts were spot on or right on the money, the adaptive would not play much of a part or be mostly inactive.
Most parts of the tune do not stand alone in the fact that if you make a change to one, that change effects one or more than one other part of the tune.
Adaptive has a range of only so much it can add or pull.
Your tune can and will drift simply because nobody can find new values that are perfect and even it one could do that, the sensors change over time and what was perfect is no longer perfect.
That is what the adaptive is all about.
You see all the time peeps come on these sites say my computer learned about my mods and all was fine.
Bottom line is some mods are not all that big of a deal as far as effecting the pcm and others are.
If you have done things such as 30lb inj's or larger, aftermarket maf, and the like, you most likely have pushed the adaptive to its max limit and that amount is still not enough for what is needed.
Trying to keep this from becoming a novel here!
You got all those brand new hot rod parts and you make your first changes to accommodate them.
Can you get close enough that the adaptive will not call for full + or - or in other words, be and stay in range to cover for a value selection on your part that might not be as close to correct as it needs to be.
How about if something unexpected crops up over time like
Say you got an issue of the O2's cooling a bit too much at idle during long stop lights.
I can tell you the tune will drift and over time and your once stable idle can get more and more unstable.
I guess I'm done rambling now
I just know from my experience ........
my dlogs showed I made an improvement
I also know those dlogs have show me .........
I was not quite close enough on the first rough draft
and I needed to go back and do a bit of editing for a more stable final result.
My knowledge is a good bit better these days ...........
If I was to get my hands on a h/c/i 94-95 Stang with full supporting mods, I really do feel I could get my first efforts fairly close
however
To get it right with one try and one try only
That is why I gotta give a
to GOOD Pro's like Don
Grady
