I have a 95GT that I want to bring from South Carolina (no emissions laws) to California. I've looked through several forums and I think I know what needs to be done to get it smog legal, but I wanted to run it by you guys to make sure.
-Smog pump and EGR in working order (duh). Need to find and install a smog pump, but the rest of the EGR hardware is still there.
-Do I need the *STOCK* h-pipe to pass?. i.e. the aftermarket h-pipes or x-pipes that have the two cats on them would not pass the visual b/c the stock h-pipe has 4 cats?
-Under the hood I have stock 5.0 motor, but aftermarket CAI, 75mm MAF, 75mm throttle-body - I'm not sure what brand (came with the car when i got it), 24# injectors, underdrive pullys, MSD blaster coil, cap/rotor, spark plug wires. Will any of these prevent me from passing? The coil came with a CARB sticker, so I guess thats OK.. but I didn't save it b/c I was in SC.
Am I hosed or can I make this work? Sorry, I'm a little paranoid b/c CA is a pain about smog!
Thanks!
Thanks!
(the car is registered in SC, they did away with emissions loooong ago).
