i replaced the t stat 195 from ford overheated blew out of the cap . ok so i decided to drill a 1/8 hole in the tstat so coolent will pass into the rad well the temps still are highlike the m or a in normal in in hot weather . if i use the A/C the fan runs all the time but still temps are high and after i shut off engine it will blow out of the cap , today i used a hose to clean out all the crap on the front of the condenser and radiator and still tems still tend to climb , is there anyway to adjust the fan to come on sooner like at 190 , i know replacing the rad will fix that problem but ill be sellling the car soon and dont want to sink a ton of cash into it , is there a quick fix ??? will ford do a recall replacement , ? also what to do with the ratteling front calipers sheesh sounds like bolts in a can when i hit a bump
, i replaced the pins calipers still move up and down . thanks for any input !!!!!!
