Hello All,
I am new to the 4.6 SVT Cobra. I had a 95 several years back but this is entirely different to me. So my questions are this 96 has 174,000ish miles on it. It's cammed and tuned.
1.Cold start there is always a white'ish smoke eventually goes away, what could that be? Is it a big concern.
2. Also when starting it takes a while for it to get up to proper idle. Usually when starting it just stays on and way under 1k idle then after 30 seconds or so it will get to the 1k idle marker.
3. It does do something funny with idling it sit just above 1k or a little under after warmed up.
4. Air intakes, i dont know what kind is on it but looks like some sort of aftermarket cone filter the air intake tube connected to the throttle body looks stock, so I would just have to get a regular OEM cone I am assuming.
5. Lately it's been getting on the warm side, when idling it does ok with heater on. Going high speeds it does great. Sensors look brand new, I do see just a little bit of coolant down by the termostat, I can't imagine that could be causing it.
6. I've been thinking about installing new egr, iac, coilpack, plugs, tps? any suggestions?
Thanks in advance!
Thanks in advance!
