  • SN95 4.6L Mustang Tech
96 GT, 2 questions
  • Thread starter Thread starter Skidzz
  • Start date Start date May 25, 2005
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 25, 2005
  • May 25, 2005
Ok I've had my GT for a month now and its been great. Only 55k miles and the only problems were the EGR valve needed cleaned and it need a new pinion seal in the diff. (I've already fixed both). Now I have 2 potential problems i need to ask about. The first is this cold gear grind issue. I searched for this first but didn't really find a clear answer. My tranni grinds slightly when the engine is cold, usually when i shift to 4th, and once in a while 2nd or 3rd. I assume i have a t-45 since its a 96. Should i be worried about this? I just fixed the diff. today and it has all new gear oil in it now. Will that help. And, how the hell to you change the tranni fluid in this car? I don't even see a dip stick for the tranni fluid. Would changing the tranni fluid help with the grind? My next question is this, i cleaned my engine the other day and accidently used too much water pressure and blew off the plastic i was using to cover my alternator, and sprayed it with water. Now i heard a faint whinning sound when the car is on that gets a little louder as a rev it up. I'm assuming its the alt. because i also notice a little power surge once in a while. Still works fine but is it the alt.? If so it can wait a while seeing as how it still seems to be functioning fine.
jmk97GT
178
  • May 25, 2005
1. Manual trannies dont have a dipstick
2. Yes the new trans fluid WILL help with the gear grind, and may or may not completely eliminate it. There is one plug to drain it and one to refil it up top.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 25, 2005
  • May 25, 2005
Ok thanks, so im guessing that the plug to drain it is under the car on the tranni somewhere, right? And where is the one to refill it located? Can i get to it from under the hood?
jmk97GT
178
  • May 25, 2005
Both are on the tranny, one on the bottom, one on the top. Has nothing to do with under the hood, you're thinking too automatic
Only way to check your fluid level is to take off the plug up top and stick your finger in.
slow96mustang
146
romulus mi
May 25, 2005
  • May 25, 2005
your alt should be ok if you sprayed it. the brushes and armature dont mind the water, and long as you had it running and didnt let the water sit on the armature, but even then, the arm is copper, and the brushes should probally be copper also. the only thing that may of went bad on it would be your regulator, but with only 55,000 on it, i cant see it. my car has 100 on it, and everytime i wash it, i spray the motor. if anything sparying the alt may help out with charging, and it would clean the contact between the brushes and armature, unless the regulator is kinda goin. maby you got a little bit of corrosion somewhere too, have you checked?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 25, 2005
  • May 25, 2005
Yep just crawled under the car a little bit ago. One tranni plug is labeled "drain" and the other "fill". And no theres no corrosion i just checked. I guess I'll have to ask a professional what the whinning is.
jmk97GT
178
  • May 25, 2005
I'd change the tranny fluid regardless of the level, its old, just get new stuff.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 26, 2005
  • May 26, 2005
Maybe someone put on a blower while you were sleeping, that would explain the whining
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 26, 2005
  • May 26, 2005
MAYBE! Oh wait........no........the ls1's are still whooping my ass.
jcint
168
wellington florida
May 26, 2005
#10
  • May 26, 2005
  • #10
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
