Ok I've had my GT for a month now and its been great. Only 55k miles and the only problems were the EGR valve needed cleaned and it need a new pinion seal in the diff. (I've already fixed both). Now I have 2 potential problems i need to ask about. The first is this cold gear grind issue. I searched for this first but didn't really find a clear answer. My tranni grinds slightly when the engine is cold, usually when i shift to 4th, and once in a while 2nd or 3rd. I assume i have a t-45 since its a 96. Should i be worried about this? I just fixed the diff. today and it has all new gear oil in it now. Will that help. And, how the hell to you change the tranni fluid in this car? I don't even see a dip stick for the tranni fluid. Would changing the tranni fluid help with the grind? My next question is this, i cleaned my engine the other day and accidently used too much water pressure and blew off the plastic i was using to cover my alternator, and sprayed it with water. Now i heard a faint whinning sound when the car is on that gets a little louder as a rev it up. I'm assuming its the alt. because i also notice a little power surge once in a while. Still works fine but is it the alt.? If so it can wait a while seeing as how it still seems to be functioning fine.
