  • SN95 4.6L Mustang Tech
96 GT vibration?? help!!!
  • Thread starter Thread starter Jacob_Royer
  • Start date Start date Nov 24, 2007
1 of 2 Next Last
Jacob_Royer
142
  • Nov 24, 2007
Hi i just purchased a 96 GT and it has a bad vibration that comes in about 40/45 55/60 it gets worse! If you push in the clutch its still there. You can feel it in the shifter and NOT in the steering wheel which makes me think its NOT tire related.. Also you can rev the engine to any rpm at those speeds and it makes no diffrence in the vibration so i dont think its engine related.. Any idea's on this would be greatly appreceated! U-joints?? driveshaft??? where is a good place to start? tranny mount?? its really bad and i want to fix it asap!
DTNODYA
831
  • Nov 24, 2007
Well, it could be a number of things but I'd check the DS/u-joints first. Trans mount is possible ... Inspect your driveshaft to see if the weights came off or if your DS has any dents in it. If none of that seems out of wack then it can get tricky and even be your motor mounts and that type stuff ... check the DS first.
FWIW, the shifter should vibrate some...
Jacob_Royer
142
  • Nov 24, 2007
Ok i will check the u-joints.. as i said this vibration is really nasty.... need to fix it...
DTNODYA
831
  • Nov 24, 2007
Does it go away at any speed or just get out of control to the point where you have to slow up?
Jacob_Royer
142
  • Nov 25, 2007
It doesent go away but at 90mph or so it gets more tollerable.. I havent pushed it past 95 yet because of the vibration...
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Nov 25, 2007
  • Nov 25, 2007
Most likely could be your DS. Does your car have gears in it?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 25, 2007
  • Nov 25, 2007
Sounds like u-joints. Same issue with mine a while back but I used the opportinity to replace the driveshaft.
Jacob_Royer
142
  • Nov 26, 2007
Figured out my mystery vibration... front u-joint $15 no biggie... Thanks for the info.. Car is bone stock so far... Need a cat-back one of the factory mufflers is blown... Ordered a cai... Also going to add a short throw shifter and UD pulleys..
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 26, 2007
  • Nov 26, 2007
That's good to know man CAI, exhaust, short shifter and pullies should be a nice addition to your car
BlackGT4.6
103
In.
Nov 26, 2007
#10
  • Nov 26, 2007
  • #10
then get gears 4.10s all the way
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 27, 2007
#11
  • Nov 27, 2007
  • #11
Oh yeah forgot that too
Jacob_Royer
142
#12
  • Nov 27, 2007
  • #12
I really dont want 4.10 gears as i like to get descent mileage... I get 22 beating the snot out of it as it is... Also have a code 1443 (i believe) somthing about the evap?? any idea what that is?? it comes and goes (cel)
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 27, 2007
#13
  • Nov 27, 2007
  • #13
It has something to do with your Aux Emission Control. Ford On Board Diagnostics II, (OBD II) code P1443 means that the evaporative emissions charcoal canister purge sensor did not detect any flow when the canister should have been purging into the engine intake system
Here's the site
http://www.rv-coach.com/current_category.181/Forum.40148/forum_thread_full.html
As for the gears, it won't be that great of a difference on mpg. It all depends on your right foot It's a great mod and I guarantee that you love it since you mash on it. Assuming you drive a lot in the city.
Jacob_Royer
142
#14
  • Nov 27, 2007
  • #14
Car will see about 60/65 miles highway daily so gears arent sounding like a very good idea...
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 27, 2007
#15
  • Nov 27, 2007
  • #15
Don't mean to pressure you but what about 3.73's then? That's what I have and it does good on the freeway for me. I drive 75mph on the freeway for about 65 miles to school and another 65 miles back, so a total of 130 miles a day. It revs about 2800 rpm at 75. But if your worried about it it's cool, it's just a great mod for our cars.
Jacob_Royer
142
#16
  • Nov 28, 2007
  • #16
I've heard that stock auto gears arent too bad..
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 28, 2007
#17
  • Nov 28, 2007
  • #17
Don't fear the gear, you can opt for a shift kit then if you do not want to do gears. You car will be a lot better with gears
BlackGT4.6
103
In.
Dec 3, 2007
#18
  • Dec 3, 2007
  • #18
why do I have to be stupid lol? I was getting the 1443 cel when my maf was bad oddly enough. I checked all the vacuum hoses the purge canister and all the rest of the evap stuff (including gas cap) and nothing. When I got my new maf it went away and as far as gas mileage with 4.10s I didn't see a real change
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 3, 2007
#19
  • Dec 3, 2007
  • #19
Sorry man. I was just agreeing with you about the 4.10's
Jacob_Royer
142
#20
  • Dec 4, 2007
  • #20
I have a 5 speed not an auto.. I was just saying that auto gears would probably be an upgrade.. BTW U-joints made the stang like a new car again and i actually picked up alot of power! driveshaft must have really been out of wack!
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
