97 cobra ET
Saleen4971
664
Setauket, LI
what do 97 cobra's usually run in the quarter? how abotu wtih a cat-back and shifter? a friend of mine has a 97 cobra with a catback and short throw shifter, and i really want to race him and see how i do, even though ill prolly loose, dependign on how much traction he gets
I was told with my mods, I should run mid to high 13's depending on traction. I can on occasion chirp third, probably more often with a shifter. Traction is definately a problem especially with the gears, even with the 295 rear tires, they break loose up in second gear, around 4500+rpm, but if you run a 14.3, it would be a drivers race.
97 Et
I have no exhaust mods and pull 13.7's. Keep in mind when the magazines state the 97 will run a 13.9, thats with a professional driver making numerous runs then the best run being stated.
It's not the magazines, it's the ford rating and with the hp the trap speed is about right. Ford rated mine at 14.5 stock and then exactly what I ran. Of course factor in elevation and driver skills. Bad tires and a bad driver can result in much less e.t.'s.
