Hey guys, I need your help big time. I have a 99 gt and the engine let go at 46k (rod bearing). I purchased a 97 gt dirt cheap with a low milage (40k) non pi engine. The motor was tight with no sounds what so ever. I swapped them out (sorry no pi intake and head swap) and on inital start up everything sounded great. As I took it off the lift and took it for its first test drive, it started ticking real bad from the passenger side head in the front. It also smells like its running a little rich and may have just a little miss at idle as well. Car still pulls real good (on test drive, havent drove it since). Everything is still stock on the car. The only things I changed was kept the accessories on the engine from the 99, also kept the cop's, and changed the clutch. My questions are: #1. Can I run the 97gt engine with a 99gt computer? #2. Has something Ive changed caused my issue?
Make sure you let the new owner know it has a 97GT engine in it. Could cause problems down the line if you dont.
