97 GT PI HEAD SWAP DYNO SHEET INSIDE
theosan
566
So. Cal.
Hopefully someone will find this usefull. The car originally dyno'd ~186 HP bone stock and rated at 215 Crank HP.
Before the head swap (everything else already on the car) it dyno'd
213.4 RWHP / 282.6 FT. LB
All in all car feels very fast and strong...and I'm happy with the result. I will be removing the C&L mass air meter and get a new dyno tune. Should be able to squeeze out 270 RWHP. :shrug:
good numbers man! hopefully you squeeze out that 270rwhp...thatll be sweet!
what do you guys think my 97 will dyno at??
MODS:
trick flow upper plenum
bbk 75MM throttle body
bbk cold air intake
bbk underdrive pullies
bbk off road h-pipe
american thunder catback exhaust
4.10 gears (dont matter in hp numbers)
bbk timing adjuster
frpp aluminum driveshaft....
last 3 dont really matter.
But how much you guys think i will pull??? :shrug:
oh almost forgot! all that PLUS my PI swap. :nice:
What does it take to get 300 HP at the wheels with a PI swap, Porting? Mild/Agressive Cams? Miracle? I am shooting for 300 rwhp in my 98 gt, and I was planning on a PI headswap with either porting or aftermarket cams....whats it gonna take to get to 300?
Pretty much everything you can think of minus a blower. P/P heads, cams, every bolt on in the book, and a great tune. It's tough but it has been done.
Ask nickthegenius his is at 290 I believe.
Mel96GT said:
Very nice but how do you pass CA-smog with that beast? :confused:
The beast is completely street legeal and always pass smog test. The h-pipe has cats and I went with shorty headers instead of long tubes for the same reason. Everything looks stock, you can't even tell that I have new heads and intake unless I tell you. :)
BTW, I didn't change out the cam to some of the nice aftermarket ones but I know I will eventually have to inorder to break 300 RWHP.
if you get every bolt on including long tubes...you could probably do it with VT Stage 2 cams and stock PI heads.
