97 t5 trans
well i have it right now and it looks just like my t-5. do the t-45 looks the same as the t-5? Also does anyone know the rating of the 97 v6 t-5 (hp and torque rating)? I compared the 97 trans next to my t5 and it all looks the same. Driveshaft fits on it and the front is the same length.
Biggest difference is that you can remove the bellhousing on the T-5 while on the T-45 you cannot. It's part of the trans.
If it is a t-5 i beleive it's rated at 300 ft-lbs.
The input shaft is longer and you cannot swap it with a 5.0 input.
The input shaft on the t-5 or t-45?
Should be about 5/8"
Do you see a buck tag located on the trans? It should be bolted to one of the tailhousing bolts.
If it's there, can you read the numbers off it and post them.
This is not worth your trouble, if in fact it's a t5. Sell that one and get the right transmission. May go in, but likely the input shaft will bind up and not spin.
No t5 is worth an input shaft swap IMO. (if in this case it can even be swapped at all).
dkins419 said:
4ZR-7003-AC REP-BBK1762
352-238 28632
numbers from the tag.
Trans 238 is what you want to look under
http://www.therangerstation.com/tech_library/T5ID.htm
It comes back as a '94-97 3.8L T-5 trans.
Yes, that extra 1/2" would make a difference.
Do you have your original T-5? You need to swap the input shaft and bearing retainer over to the V6 T-5 to make it work. This MAY NOT work as te gear ratios would need to be identical. I do not know if a Fox input will work in a V6 trans. If you have one handy you can try to swap them, but i wouldn't make you spend $$$ to do so.
Keep in mind this trans is weaker...only rated at 265 ft-lbs of torque
they can be swaped..... so ive read because iwas gunna buy a 94 sn95 v6 for my 460tt project go under the v6 forum youll find all ya need to know
from what ive read the v6 t5s are the same as the earlyer moddle t5s minus imput shaft i even belive the bell housings are the same and if you have yer old tranny go for it and swap it
