  • SVT Tech Forum
98 cobra starting problem
  • Thread starter Thread starter 66gt-350
  • Start date Start date Mar 11, 2004
66gt-350
25
Sacramento Ca.
Mar 11, 2004
  • Mar 11, 2004
I just bought a 98 cobra and I am having a problem with it not wanting to start. i have to crank it for a while to get it started. It does always eventually start though. I am thinking it is a fuel pressure problem. any help is greatly appreciated. It has 48k miles
sirhisss
260
Quincy, WA
Mar 11, 2004
  • Mar 11, 2004
Go back to the basics.
Since you just bought it.
How old is the battery? Have it tested.
1. Change fuel filter.
2. Check fuel pressure Key on Engine off about 35 lbs.
3. Engine run Idle Fuel pressur should be about same.
4. Since it is a 98. change the plugs and wires. Make sure you do it correctly. anti sieze on the threads and silicon dielectric in the wire boots.
5. Check for any pending codes. Fix if necessary.
6. Disconnect battery to reset ECM
7. Go for a drive so that ECM relearns the engine parameters.
8. If that don't fix it then start looking deeper.
Good Luck!
66gt-350
25
Sacramento Ca.
Mar 11, 2004
  • Mar 11, 2004
Thanks for the info, i will start with the pressure check. I suspect that it is low because when it does start it stumbles and sounds weak for about 5 seconds.
sinisterblack98
Sometimes I just lay on my garage floor and look u
967
Motor City, MI
Mar 11, 2004
  • Mar 11, 2004
If still original...change the spark plugs. They need to be done much sooner than the manual says. I've actually felt ass HP twice changing them at 20,000 miles on different 1998's, besides easier starting.
sinisterblack98
967
Motor City, MI
Mar 11, 2004
  • Mar 11, 2004
WTF is the "sponsored" eBay link on spark plugs?
I didn't do it!
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Mar 11, 2004
  • Mar 11, 2004
I didn't do it!
It's ok, don't worry. LOL Welcome to "embedded" advertising. SN decided to go this route in order to help support the site & forums. I just ignore 'em...
66gt-350
25
Sacramento Ca.
Mar 12, 2004
  • Mar 12, 2004
What plugs should I put in it, as far as brand. thanks again for all of the help guys!
sirhisss
260
Quincy, WA
Mar 12, 2004
  • Mar 12, 2004
While stock Pretty much anything OEM equivalent as long as NOT Champion. IMO
With the power adder. IMO non platinum. Some like Denso, NGK others Autolite. If copper tip you will need to change more often.
I currently am running Bosch (easy guys I know many don't like 'em). I haven't had any issues with them wherein others have.
66gt-350
25
Sacramento Ca.
Mar 15, 2004
  • Mar 15, 2004
Thanks for the info I am going to change them tonight!
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
  • SVT Tech Forum
