Hey y'all, newbie here. My 98gt 4.6 (96 motor) runs well when below normal operating temp. After warm up, It starts to buck after changing gears (all gears) and then dies. Check engine and air bag light sometimes comes on when it happens. I come to a stop, turn off ignition, then turn her back on. All lights clear, but still bucks and dies. Sometimes the lights come back on. I've read some of the threads and ended up replacing the following, to no avail:
Crankshaft sensor and connector, camshaft sensor, plugs, plug wires, both coils, clutch assembly, fuel filter, temp sensor, cooling fan assembly (had busted blade and fan motor locked up), alternator, oil filter housing gasket (massive oil leak), and pulled throttle body and cleaned thoroughly. Not sure what is next. Any ideas are appreciated. TIA
