Does anyone know if I would have to remove the oil pan to take off my timing cover. My Chiltons guide is saying that the SOHC engines would need to remove the oil pan to take the Timing Cover off. That would would require me to actually lift the engine cause the crankshaft would be in the way. I want to avoid removing the pan. Looks to be only a couple of bolts holding the cover to the pan. These guides are nortorious for adding extra unneccesary steps. Yay or nay for the removing of the oil sump. I really need to change my chain guides and tensioners.
? I assume that if nothing is turned, I wouldn't have to re-time, correct me if I am wrong.
