99 01 cobra cross member
ford67boy
ok so i have a tremec tko 500 installed in my 94 cobra but the mount wouldnt hit the crossmember in the original position. i flipped it 180 horizontally and the mount now hits the cross member but im sure it causing the driveline angle to be off i messed on the intake and it measures and same incline the driveway does. my question is i think thats the tko 500 is the new version of the trans used in 99 01 cobra and wondering if the crossmember from one of those cars will work. hopefully that also makes the vibration i have go away to. if someone has some time to take a measurements for me from the engine mounts to the trans mounts on frame and from bolt holes on the the brakect from side to side and from block plate to trans mount thats wud greatly appreaciated.
