  • SN95 4.6L Mustang Tech
99 2V Draining Batteries??
  • Thread starter Thread starter BrninRbr99
  • Start date Start date Jan 20, 2009
BrninRbr99
  • Jan 20, 2009
Hey guys and gals.... I'm the new guy and I recently bought a 99 2V with a 5 speed. It's got 68000 miles on it and the motor was replaced at 29000 by Ford under warranty. Other than that it is bone stock. If it sits for a week without being run the battery is dead. When I connect the cables to the battery there is quite a draw. Just wondering if there is a relay or something common that might cause this?
Any other tips of things I should know would be awesome.
03 Mustang gT
103
seaford, New york
Jan 21, 2009
  • Jan 21, 2009
sounds like the battery might just be a bad battery and time for a replacement
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jan 21, 2009
  • Jan 21, 2009
How much of a draw? Do you have access to a multimeter and can hook it up in series and measure the draw in A when the vehicle is off?
If it's signigicant, you can start by pulling fuses out and trying to isolate the problem circuit.
Also, once a battery has been drained and jumped...it will never be the same and hold a charge as well, so it will drain easier the next time. Once you discover the source of the drain, replace the battery
BrninRbr99
  • Jan 21, 2009
I got a new battery and a week later it was low enough were it didnt start. I took the battery out and i got the battery to charge. I will try to pull fuses while i check the draw.
Thanks and hopefuly we will see what it is.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 22, 2009
  • Jan 22, 2009
check the alt. they go bad and cause a drain
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
D
Massive battery power drain
  • DanB93
  • Jul 7, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 8, 2023
Mstng93SSP
W
Some weird electrical issues
  • Watumpka
  • May 23, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- May 23, 2023
Watumpka
W
A
Electrical '89 GT Fast Drain of Battery - Battery Won't Charge When Connected
  • aroorda
  • May 15, 2022
2K
Fox 5.0 Mustang Tech Jun 3, 2022
Mustang5L5
Electrical Battery Drain / slight draw
  • R82148V
  • Jun 2, 2022
3K
Fox 5.0 Mustang Tech Jun 2, 2022
Mustang5L5
