99 Cobra brakes help
One thing that's not common between Fox brakes and the Cobra brakes is related to the rear discs. You'll need a disc brake piston tool in order to "reset" the caliper from the position it's automatically adjusted to during normal use. The tool fits into a couple of notches in the piston and then you manually crank the piston back down towards the caliper base so that you'll have room to install the new pads. Pretty simple and the tool's pretty cheap - roughly 6-12 bucks. Good luck.
