99 gt intake manifold
99mikeGT
396
Montgomery, NY
99 gt intake manifold problems
the other night i was driving around and after runnin my car hard i smelled antifreeze pretty strong. i got back to my house and i noticed as my rpms went up, i could see the antifreeze beginning to leak out from behind the alternator onto the block but when it idled it did nothing. i was told by a ford mechanic that it was the intake manifold leaking and that there was a recall on it. after lookign into the recall he told me my model 1999 GT was not covered in the recall for whatever reason. Well im not the wealthiest kid on earth so the $651.00 will really hurt me if i have to buy a new one from www.GEFRACING.com. Does anyone have any ideas/ suggestions for me?
Not sure where the $651 comes from. This is the intake you need and you can easily change it yourself to save on install charges.
http://www.gefracing.com/Merchant2/...&Product_Code=M9424P46&Category_Code=46INTAKE
Mine did that and it turned out to be bad gaskets. I got a new intake for stangstore.com and it was like $300 and the gaskets are like $20 a peice. make sure that the gasket is good before you goo buy a new intake cause I didnt even need mine.. Sorry to hear about your troubles man I feel for you. Get the problem fixed before the coolant makes its way down the spark plug hole then you need new boots and plugs :notnice: Thanks ford for yet another screw the customer>>> :mad:
4.6_02_Black_GT said:
Isnt there a coolant hose that runs through the engine valley under the intake, could it be lose or have a hole in it. Maybe this is where he is losing fluid :shrug: :shrug:
Not likely as the tube is made of metal and is stationary. More than likely, the plastic is cracked, but yes try and be as sure as possible so that you don't spend money on non-necessary repairs.
