Problems now: Main issue now is when the AC is activated, the idle fluctuates and when the AC is turned off, it dogs the system. Idle will remain low. I was having random idle issues with no AC but was fixed.
Fixes:
- Ignition Starter Switch
- Cleaned Throttle Body and Plenum
- EGR Valve
- Cleaned MAF
- IAC Valve
- Fuel Filter
- Air Filter
- Battery
- Alternator
- Serpentine Belt
- Spark Plugs
- Battery Terminals
- No Vacuum Leaks(that could be found)
- I hope I listed all
I have spent some time working on it. Random idle fixed. Now need to know about the AC. Could it be low freon or bad compressor?
Fixes:
- EGR Valve
- Cleaned MAF
- IAC Valve
- Fuel Filter
- Air Filter
- Battery
- Alternator
- Serpentine Belt
- Spark Plugs
- Battery Terminals
