'99 Novi 2000 Intercooled entire kit
71
Ok guys.. I'm switching to a KB and don't need this anymore. Just took a bunch of pics with how it sits on the car right now, moments before I tear it all out.
Headunit only has a max of 5k miles. Its sat in my garage for most of the time. You can see by the serial number that its fairly new as well. Don't mind the dust/dirt as its been sitting for 6+ months.
For someone with a '99 3bolt tensioner timing cover this will fit just perfect and be an entire kit to make 600hp easy or pulley it down to make 400 on a stock motor.
I also have the bracket for a 2000-2004 timing cover, but a few of the bolts/spacers will need to be purchased from paxton in order for it to work.
Comes with everything you see, minus the p51, filter, mafia and engine pulleys.
Novi 2000 Headunit with 8rib 2.9 RR or 3.0 RR pulley or stock 3.5 6rib
AFM Powerpipe
Vortech mini-race bypass valve
SCT-5000 '05 slot style MAF
Ebay bought intercooler custom mounted
Installation manual
All you will need is a fuel system (injectors, pump), tune and tap your oil pan!
Headunit itself is 2400 new
$3000 Shipped OBO from 91206
PM me with any questions... I get instant notification and can respond through my iPhone. I can help you with any install questions as well after you buy the kit.
Also check out my P51 manifold for sale:
Black ported P51 intake manifold - ModularFords.com
Here are all the pics... I tried to take a pic of every part possible so you'd be able to install it exactly the same way.
