billfisher
i would personally start with the fuel pump relay. if its pulling in and voltage is in the 10 gauge wire woing back to the fuel pump. the wire travels jst behind the fual tank. it has a quick disconnect. check for volatage there if u have it at the relay.
if the relay doesnt pull in, you knwo where to lok, fuses etc. one concern 96pcm uses a return pump not a variable duty like 99. im not familiar with the 99 v6 pump. does it have a 79-97 fuel pump in it?
