here is what i have
i have a 99 mustang that had a V6 i replaced it with a 93 lincoln MK8 4.6 dohc
(got it for free 38,000 miles and bad bags) the mark8 ran perfect but now i have it in my mustang got mostly everything hooked up
i am using a 96 cobra upper and lower intake and imrc's with butterflies deleted
stock mark8 engine harness (i will eventually use a cobra harness)
a 96 cobra PCM and a 96 cobra PCM harness
now the 93 mark used the EDIS8 module while the 96 cobra didnt
so i wired the motor up like it was a 96 cobra ran everything through the PCM but didnt use the EDIS of course
and i have power at my CKP and i have power at my coils....the middle wire i think its red/light grn
i have the yellow wire at the pcm pin 55 at constant power and pin i think 72 and 91 i think those are the right numbers are 12v in run and start
when i turn the key on i have power at the coil(red/lghtgrn) but the problem is is when i have poser at that wire the other 4 wires (between the 2 coils)
there is 12v there too is this right??
my engine turns over by the key i tapped into the wht/pk wire that is only hot in start and it works good that way
i dont know if i am getting fuel the other wires that run through the firewall for the PCM harness are not hooke up because between 96 and 99 the plugs are different they just run the rear lights fuel pump and dash junk.....
anyone know if its my PATS ??
tell me what i am doin wrong i have no spark
