a/c charging
pony50boy302
18
hello people .. i have a 93 gt .. my a/c blows strong and cool but not ice cold ..
At idle the compressor clicks on and off so im guessing its just a lil low on freon ..
the engine has 32 k and is very clean and i dont think it has a leak .. i think i may just need a can or so of freon added .. so i got some of that freeze 12 stuff to put in it and i have a couple of questions ...
i do not have the a/c gauges .. can i do this without them ?
i was thinking of slowly releasing the freon into the system untill the vent air is coming out cold ..
what should the air temperature coming out of the vent be if my ac is on hi and working properly ????
will the system just stop taking the freon when it is full or is it possible to overflow the system ???
which valve do i connect the freon too , the one on the compressor itself ??
thanks for all your help guys and info or tips would be greatly appreciated ......
how fast does it click on and off?
the compressor should cycle on and off when the a/c is on. once the high side builds to a certain pressure the pump kicks off until it drops to a certain pressure
you can try and add some to it and see if it gets better, if i remember correctly you charge on the high side, but i haven't messed with a/c in about 6 years so i might be wrong
DO NOT charge the high side.
When the system reaches a minimum pressure (generally 15-20 PSI), the LPCS kicks the compressor off so the compressor doesn't burn up.
Due to people doing stupid things, I often don't reply much on AC threads anymore. For a very nice overview, search for Puter's AC article and Jrichker's AC article. Do such work at your own risk. AC work is one thing where you really want to know what you're doing before you start. Being quite sure of cross-compatibility when dealing with different types of refrigerant is also very important.
Please protect your eyes and skin when charging the system as well.
Good luck.
it clicks on and off every minute or so .. i dont know which is the high side or low side .. i just know theres a valve on the compressor itself and one on the line running to the compressor
