a/c leak?--help!
95lolaGT
sometimes there's cool air when i run the a/c, but when it's 100+ (which is everyday in houston), the air isn't as cool and is sometimes warm-ish. the compressor also kicks off and on. thought i needed a recharge, so went out and bought one of those recharge bottles at the autoparts store... hooked it up and the gauge said it was full, compressor kicked off and the gauge dropped to zero. could i have a leak? don't know much of anything about a/c systems, but if its a quick fix i'd rather do it than take it to the shop...
first i need to know if the reading u r getting is with compressor running or off, if the compressor is riunning your low side should be between 35psi and 45psi, if low side pulls down below 20 or 25psi the low pressure switch will cut compressor out till pressure comes up to about 50psi.
What you describe about the AC pressure sounds completely normal. When the compressor is on, you will get a pressure reading. When it's off, you will get no pressure reading.
That is why the AC recharger kit's instructions tell you to start the motor, turn AC on full blast, then check the pressure.
As far as getting no AC on really hot days, that may be completely normal too. Has this happened in the past? Have you made any significant mods since you noticed the issue (if it hasn't happened in the past)?
Here's a really easy possibility, check to make sure the AC compressor is still connected (to the electrical harnace). I forgot to hook mine up on reassembly when putting my HCI build back together, and I noticed similar simptoms as you describe (works well sometimes, but gives out, especially on hot days). I reconnected the AC compressor, and I was good to go.
Good luck.
