when i got the car, the a/c wasn't working--turns out all it needed was a new pressure switch. i replaced it about a month ago and it started working fine, even did a coolant recharge. a/c stopped working a couple days ago, though--all it does is blow hot air.
question is how do i jump the pressure switch to test it and see if it's gone bad? there arn't any leaks--checked the hoses w/ the guage the coolant recharge kit comes with. i'm hoping it's just the switch, but why would it go bad so soon? any suggestions welcome, thanks guys.
The low pressure switch is mounted on the top of the accumulator? near the firewall on the passenger side. I think the wires are purple and blue. The switch should also show no resistance(if system has refrigerant in it) with KEY OFF. If the low pressure switch doesn't read 'shorted' then it's bad. Your A/C pressure gauge should read well over 100psi on the low side if the compressor is OFF. The low side switch 'opens' if the psi is below 25psi.
