I'm trying to get my original A/C working in my 67 mustang.
The car was missing some of the A/C parts when I first bought the car so the A/C was never working since I've had it. I bought a rebuilt compressor, receiver/dryer, expansion valve and all new hoses and service valves for a R134 system. I've had the system evacuated and recharged through an A/C shop with no leaks, but the temperature only cools down to 70 degrees. The A/C shop says the pressure is good and told me I might have a problem with some baffle not functioning. The Air Selector switch directs the air correctly for Max, Freshl, Heat and Defrost so I'm not sure if a baffle is the problem. The only two things I haven't replaced are the condenser and the evaporator.
Anyone have any ideas on what else might be causing the problem?
