  • 1994 - 1995 Specific Tech
A/C problems...
  • Thread starter Thread starter Road_Runna
  • Start date Start date Aug 11, 2004
R
Road_Runna
20+ Year Stangneter
Dec 23, 2002
594
Ogden, UT
Aug 11, 2004
  • Aug 11, 2004
Hey guys, my A/C isn't working, it keeps on blowing warm air, even after I have the car turned on for more than 5 minutes.
Any ideas. I wan't to keep it, so plz, no A/C elimanator comments.
jermy82
446
Sherman, Illinois
Aug 11, 2004
  • Aug 11, 2004
Hopefully it just needs to be recharged, in that case I think you can just get a recharge kit from walmart or an auto parts store. I'd check it for leaks though before that...could save you some money in the long run. I really don't think A/C is the area of expertise most people have on here unfortunately....hope this helps a little, and good luck.
viperos
2,943
Bellevue, WA (yes, the land where every 16 year o
Aug 11, 2004
  • Aug 11, 2004
the same problem happened w/ my taurus (1992) so, from what I've figured out in the taurus, there's no actual reason why it's doing it, or how to fix it, but if the knob for the temp is on the cold position when you shut off your car, and start it in a while, you should be able to have cold air
however, this might not be the same problem, so hopefully, you just need it to be recharged good luck w/ it though
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 11, 2004
  • Aug 11, 2004
You need to see if there is refridgerant in the system.
Get one of the r-134a recharge kits from autozone that has a pressure gauge. Hook it up to the driver's side fitting. Check for pressure. It should be in the blue zone. If not, it has a leak. If it's fully empty, you could have more serious problems (like blown compressor, etc)
Add some flourescent dye, and recharge the system. Once it leaks out again, use a blacklight to find the leak. Repair the leak, and you are done!
Hopefully it's just a leak and it will be a cheap fix!
Scott
Sleepy McNastee
491
Lawrence, KS
Aug 12, 2004
  • Aug 12, 2004
Yeah it could be a number of things.
Have someone turn on the a/c, while you are listening under the hood for the a/c clutch to engage the compressor. You should hear a click. If you can't hear a click your compressor probably isn't turning. So you will not feel cold air coming from your vents.
You could be, as said before, low on refrigerant or have water in your system. Or you might have a clogged system.
Also, if you do this yourself, remember that it's good to add oil to the sysem. The oil lubricates the pistons in the compressor, so its wise to add oil every time you recharge your a/c system. Our systems need 7oz. PAG (polyalglycol) for every full flush/recharge, but I wouldn't be surprised if there is PAG in the recharge kits you can buy at autozone...
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
