A/C recharge
I have a 92 lx 5.0. Realized that the reason that my blower only blew warm air out of the defroster vents was due to a vacuum leak, caused by the previous owner removing the condenser. All other a/c components remain. Once I replace the condenser, can I have it recharged with freon, or do I need to convert?
The condenser by the radiator is gone? Did he plug the lines? You will need to make sure the compressor turns fine and replace the dryer since it has all absorbed water and is no longer any good. I'd lube & replace all the o-rings too. If you can get r12 and can make sure there are no leaks, then a recharge with r12 would be the best way to go. You can convert if you want to, r134a is quite a bit cheaper than r12.
