A/C troubleshooting
  • Thread starter Thread starter stroked50
  • Start date Start date Jul 16, 2005
stroked50
12
  • Jul 16, 2005
I just picked up an '88 GT and am trying to get the A/C working. I know that at some point the motor was swapped. Everything for the A/C system is there but I can't find the wiring that goes to the A/C clutch anywhere. Could anyone identify for me, where the wire runs from and what colors they are. The Hayne manual didn't have the diagram for the '88, only the '87. Is it the same. (black w/ yellow) I've search all over the compartment and can't find anything.
Thanks
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jul 16, 2005
  • Jul 16, 2005
Not sure, i'll have to look, but how many extra wires do you have that are unhooked?
stroked50
12
  • Jul 16, 2005
Everything seems to be hooked up. There just isn't anything going to the compressor. I'v looked from under the car and above and can't find a plug to go to the A/C. I was hoping to find out what other things are fed from the wire loom that the compressor plug is in so I know what area to look. On an 88 LSC 5.0 motor I have, the compressor is fed off the same loom as the coolant temperature sender, but my car is different.
Thanks
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Jul 16, 2005
  • Jul 16, 2005
I'll check when i home tommorrow and give you an idea of where they come from, just in case someone cut the wires off your car.
RYC CUKR
1,437
Orlando
Jul 16, 2005
  • Jul 16, 2005
I believe that the wiring harness that feeds the A/C clutch has two wires and they are black and black w/ yellow tracer. It should be on the drivers side of the engine compartment. If you can find the WOT A/C cutout relay you might be able to trace it out to where the harness is or should be. If you can't find the relay you can start at the A/C low pressure switch and trace from there. It should remain a black w/ yellow tracer from the pressure switch to the relay and then on to the clutch. That is the 12v to the clutch.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 17, 2005
  • Jul 17, 2005
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
stroked50
12
  • Jul 17, 2005
Thanks for the info. I did pick up a black w/ yellow from the wot relay. I f I'm still on the right wire on the driver side, it goes to a 3 wire harness where it is terminated. I'll keep looking into it.
Thanks
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
W
ziebart imobilzer removal and issue
  • waynewl34
  • Mar 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 30, 2025
