A different Mark VIII question
  • Thread starter Thread starter Klunky
  • Start date Start date Apr 19, 2004
Klunky
290
Kansas
Apr 19, 2004
  • Apr 19, 2004
I did a search already and couldn't find much. I've got a 3" Granitelli aluminum radiator in the GT. Do you all think I still have enough room to install a Mark VIII??? Thanks.
TIMMY2734
1,330
Queens, NY
Apr 19, 2004
  • Apr 19, 2004
I BARELY had enough room with my Fluidyne, which I think is around the same thickness
BlackFox5.0
3,514
Massachusetts
Apr 19, 2004
  • Apr 19, 2004
I had one hell of a time fitting mine in with a PepBoys 3-core. I had to take out the washers onthe water pump bolts, and shave down the heads on the bolts. then I put my blower in and had to mount it upside down and make brackets for the fan, and get a junkyard overflow tank.
Klunky
290
Kansas
Apr 19, 2004
  • Apr 19, 2004
That's what I was afraid of. I like the idea of freeing up some extra power, but not if it's such a PITA.
I'll just put that money toward a nitrous kit and make some power that way.
Stang951
1,129
New Orleans
Apr 19, 2004
  • Apr 19, 2004
I installed mine on a Griffin 3-core and have some clearance. Not a whole lot but enough to operate.
Mine is upside down as well, and it was trimmed about 1/2-3/4".
Klunky
290
Kansas
Apr 19, 2004
  • Apr 19, 2004
MAN that is a close fit! I think I'll save that project for when I'm really bored and don't mind spending some time making it right.
Stang951
1,129
New Orleans
Apr 19, 2004
  • Apr 19, 2004
Took me a few hours, not that bad though. It took more time to wire it the way I did than installing the fan to the radiator and cutting the shroud.
baskin
152
Apr 19, 2004
  • Apr 19, 2004
Here are dimension dwgs of the mark viii and taurus, along with flow numbers vs current
http://www.dccontrol.com/3018info.htm
http://www.dccontrol.com/3516info.htm
about 1.5" can be trimmed from the m8 fan.
If you can't go with the m8, the taurus fan also flows very well
BlackFox5.0
3,514
Massachusetts
Apr 20, 2004
  • Apr 20, 2004
Here is how close mine was before I flipped it.
If you don't want to use the Mark 8 Fan, then why not try the Taurus fan? Here is mine when I had it. I only upgraded to a Mark VIII fan because I found one and wanted one before, so I upgraded
Klunky
290
Kansas
Apr 20, 2004
#10
  • Apr 20, 2004
  • #10
Is a Tauras fan a lot thinner or something?
BlackFox5.0
3,514
Massachusetts
Apr 20, 2004
#11
  • Apr 20, 2004
  • #11
I think it's the same after you cut them both down, it might be a little thinner, it's also above the pullies the way I mounted it...
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Brakes ABS in a Fox - Mark Bettin
  • AeroCoupe
  • Mar 28, 2025
2K
Fox 5.0 Mustang Tech May 17, 2025
AeroCoupe
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
