  • 2005 - 2009 Specific Tech
A/F gauge help !!
  • Thread starter Thread starter johnnyluvchx
  • Start date Start date Mar 7, 2008
J
johnnyluvchx
  • Mar 7, 2008
Greetings all, I am about to install a autometer cobalt narrow band A/F gauge on my car. does anybody know if it is better to tap the purple/green wire on the first pin on the pcm, or the o2 sensor before the catalytic converter. any help would be great. please let me know the pro's and con's to each.thanks for any info in advance.
john
belzebub2u
164
Woodstock GA
Mar 8, 2008
  • Mar 8, 2008
are you running a power adder? or can you weld a bung into your exhaust? i purchased the o2 sensor kit for that gauge, and it works perfectly, i did not wanna tap my pcm. . just in case i screwed something up.
BumbleStang-05
Ft. Hood, TX
Mar 11, 2008
  • Mar 11, 2008
A/F Gauge assistance.
I am thinking about doing the same on my car, but not sure where to buy the gauges from, or which gauges to choose. Where did you purchase that kit for you gauges? Got a link? Sounds like a simple fix. Thanks.
05 Gt, Auto, Yellow w/ Black Stripes, S&B CAI, GT 500 TB, MotorVator TB Spacer, SLP Loudmouth Exhaust, more to come in the near future.
belzebub2u
164
Woodstock GA
Mar 11, 2008
  • Mar 11, 2008
may not be the cheapest, but i live pretty close to the showroom, so i just got them there
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-6175&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-2244&N=700+115&autoview=sku
BumbleStang-05
Ft. Hood, TX
Mar 11, 2008
  • Mar 11, 2008
appreciate the help. plan on doing the install myself, doesnt seem hard at from what i have read. any sugguestions on how to go about it or easiet way to do it, as far as running the gauge wires goes keeping a clean appearance?
belzebub2u
164
Woodstock GA
Mar 11, 2008
  • Mar 11, 2008
the best piece of advice i can give, is there is a grey plug under your console that has a 12 volt ignition wire in it, splice into that
mhanksii
336
Maryland
Mar 11, 2008
  • Mar 11, 2008
could you be a little more specific about what wire you are using? I am about to add gauges to my car too and have enough trouble wiring things up, lol.
05xgt
78
spring tx
Mar 11, 2008
  • Mar 11, 2008
I am also installing a narrow band a/f guage by autometer. One thing I'm doing is welding a bung in the center of the cross over pipe so it will monitor both sides instead of just one bank. It should read both sides and then avg it out. JMO
belzebub2u
164
Woodstock GA
Mar 12, 2008
  • Mar 12, 2008
hmm, i will see if i can see under there, but its all covered now, but you can use a test light to identify it.
millhouse
1,985
Simpsonville, SC
Mar 12, 2008
#10
  • Mar 12, 2008
  • #10
In case your not already away….get ready for the narrow band light show. Really, a narrow band AFR gauge won't allow you to do any tuning, and wont give you any usefull unformation that you don't already know. They are IMHO a complete waste of money. I'm not trying to rain on anyone's parade…but rather trying to help those from making a purchase they will regret later.
Emay
228
South Elgin, IL
Mar 12, 2008
#11
  • Mar 12, 2008
  • #11
I saw this and was going to just pass it over in order to not offend any one. However I have to agree the cobalt narrow band is simply a light show as mentioned above.. You can't tune off of it and it doesn't supply any hard data.
The route to go is a wideband, they are ungodly expensive gauges for a reason.
If your tuner is worth his weight, no need for a wideband unless you will physically be datalogging and tuning your own car on the fly.
Outside of that, if your going through with the install of this narrow band, Do as previously mentioned, punch a hole in the exhaust and weld in a o2 bung for a clean install. If you ever hit the dyno, they can use that location for their wideband hook up.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
