My a/f ratio is 11.6 at wot. On the 3-valve engines it is very important to have the proper ratio while under boost or you will have a useless engine block when it blows. On the other hand, running too rich will cause it to code repeatedly on you. I wouldn't mess with it if that's what you are thinking. Have an experienced '05-up tuner do any changes to your system.
