A few cooling system Q's
Green_Meanie
161
I am in the process of replacing some cooling system components.
Here are my questions
1) Should I replace waterpump with a new high flow unit? If so which one?
2)should I keep my stock fan or run an aftermarket fan on the Fluidyne? If so which one?
Thanks.
I dont know of anyone that makes a highflow bolt-on pump for the 94-95GTs. The same goes for the fan. A few companies make fans that will work, but they are not a direct bolt in. I know of one place that sells an aftermarket OEM fan replacement, but Im not sure of the company that makes it.
i don't think you will find a better fan, but with the fluidyne in my car i used a flexalite 16" fan for a long time with sufficient cooling w/o ac, so that should tell you something about the fluidyne, try to use that fan with the stock radiator :nono:
