Note: If there are different answers for different years, I have a 76 Ghia. But please let me know the differences if any, since I would like to avoid buying stuff that won't work. I really don't know much about these, but coming from a vintage Mustang history those cars changed a lot every couple of years and lots of parts aren't swapable between some years.
First one. Is the trans crossmember the same for a manual and an auto trans? I realise that changing to an aod or T-5 changes everything.
Second one. V8 motor mounts?Both the frame and block. I have heard that these are hard to come by. Especially the frame mounts. Are there other options besides using an engine plate if I can't find them? I currently have none, unless the current owner has some stashed away(he has a lot of parts in his shed that he is throwing in, but don't I know what). And if he does they would be for the V6, not the 8.
Third. Is there any sort of faq or listing of what can be used from other cars in general besides going out and buying a Hollander's? Having a Pinto I know some stuff swaps, but generally what I know about is going from a II to a Pinto. Rear axle, brakes, etc.
Fourth. Other web forums. I have tried to register on a couple other sites that state that the admin has to manually approve and haven't heard anything back. Any ideas on how long I should give them? So far I like this place best
, but I would like to get as much info as possible.
thanks,
Russ
, but I would like to get as much info as possible. thanks,
Russ
I already anticipate replacing just about everything on it.
