i am just starting to plan out the rebuild on my old 289 (casting number C5AE-6015E, its an old 66 rusted out 2bbl), and wanted some input from you wise folk here. first off, im on a budget, so i am planning on getting anything that needs machining taken care of, and then build the engine myself with the help of family and friends. what i want to do is build the short block strong the first time around and then reuse and rebuild the heads, intake, carb ect. until i can earn enough money to take care of the the top end in a year or so.
1) i am reusing the connecting rods, crank and bearing caps, they all seam to be in good condition. i want a high reving motor and i was wondering what rpms i could expect out of a 289 with stock components. i eventually want 300hp+ at the wheels and i was wondering if it would help to either get some studs for the main caps instead of the old bolts or maybe even a girdle, but i dont want to go overkill.
2) does anyone have preferences when it comes to brands of rebuild kits or pistons, rings, gaskets, timing chains, or any other parts that i need to build a bullet proof bottom end?
3) here is a tranny question: i am using the old 3 spd stick as well the 2somethingratio highway gears for a while until the engine gets the way i like it. i will replace the rear end in the distant future, but i was wondering if the 3spd is worth anything as far taking some punishment from hard launching and shifting. is there anything out there to help improve this transmission or should i just start looking for a 4 spd toploader?
i think thats it for now, and i thought i should mention it will be a daily driver, so driveability is definately an issue.
thanks in advance-
Chuck
thanks in advance-
Chuck
