There is no secondary idle circuit on a Holley 80457. This is a 4160 model Holley, which have a secondary metering PLATE, in place of the model 4150's secondary metering BLOCK. ( this is the main difference between the two models, most other parts of these are interchangeable). As for your hiden stop screw, it's either there or not, it's not hidden, if it's there, it's on the passenger side of the carb, where the throttle rod pokes out. I've never had to mess with this screw,( all my engines idled without needing to have extra air flow) and never really paid much attention to what carbs had it and which ones didn't. The only Holleys that have a secondary idle circuit, are the 4150's ( some not all) and these are obvious, as they have the mixture screws sticking out the sides of the metering blocks ( not plates)
