Come again? Are you asking what parts you should keep from the 302? I'd venture to say none if that's what you're askingBut the bronco used a 302 as well. Just curious if you guys could tell me what I would need to preserve the 4x4 if I was to swap a coyote motor into a bronco?
Yes lol. And if anyone has transmission suggestions. Done some research but I'm thinking the coyote won't work well if I wanted to preserve 4x4Come again? Are you asking what parts you should keep from the 302? I'd venture to say none if that's what you're asking
Ohh so your main concern is being able retain 4 wheel drive? What are the new trucks using? I'm of very little help but I'm sure it could be done but I imagine it'd be pricey. The coyote and the pushrod 302 are completely different animals. If you're wanting more power it'd be cheaper to do heads, cam, and intake.Yes lol. And if anyone has transmission suggestions. Done some research but I'm thinking the coyote won't work well if I wanted to preserve 4x4
Unfortunately the motor in the bronco is shot. Cheaper to swap then pay someone to rebuild because I have no idea how to rebuild lolOhh so your main concern is being able retain 4 wheel drive? What are the new trucks using? I'm of very little help but I'm sure it could be done but I imagine it'd be pricey. The coyote and the pushrod 302 are completely different animals. If you're wanting more power it'd be cheaper to do heads, cam, and intake.
Yes. Little things are different like the firing order but it'll bolt in. If the fox 5.0 is stock then you'll loose some torque in the low rpm's due to the heads. If you're wanting to "go muddin" you wanna make power at a lower rpm. How often are you going to be spinning at 6k rpm unless you're stuck. Ya know what I mean?So that leads to my next question, if I was to just swap the 5.0 to my fox, will the 302 from the fox bolt in the bronco?
Go on and put it in, it'll work. Check out the mid 80's/early 90's f150 and full size bronco forumsUnfortunately the motor in the bronco is shot. Cheaper to swap then pay someone to rebuild because I have no idea how to rebuild lol
Thanks. Swapping the coyote into the fox will be a pretty penny as well I'm sureGo on and put it in, it'll work. Check out the mid 80's/early 90's f150 and full size bronco forums
Good answer good answerIf you want the coyote swap your best bet would be the complete drive train from a new f150.
Swapping in a warmed over 302 h.o would be a much cheaper alternative and if you score an explorers 5.0 it's worth about 60hp over what came in the bronco.
The e7 heads on the bronco abd mustang engine are identical. Difference is in the camshaft and the intake. With truck gearing you won't even notice the hit in the low end.
