  • 1994 - 1995 Specific Tech
A little suspension help.
  • Thread starter Thread starter 95Vert
  • Start date Start date Apr 5, 2005
95Vert
1,785
North Mexico (deep south Texas)
Apr 5, 2005
  • Apr 5, 2005
I finally got around to installing my new suspension and it took 2 of us all day to get the rear in and today I'll be doing the front. I don't know how to install the c/c plates. I have the 3 bolt ones but I needed some help. What do I do to make the install simple? Also, my control arms have the greaser nipple but I don't know if they already came greased or I have to grease them, what do you think?
Thanks
PS, I'm installing the sportlines, tokico shocks/struts, mac control arms, and steeda aluminum cc plates.
RIO5.0
6,892
N.H.
Apr 5, 2005
  • Apr 5, 2005
The CC plates arent all that bad to install...Just follow the instructions and it should be cool....The only thing I'll offer up is to match mark the nut centerline before dis-assy....simply put masking tape on the fenderwell in front and on the sides.... standing in front of the nut, take a Sharpie or whatever and mark on the tape where the strut nut centerline is....go to the side and do the same....put the tape where its not gonna be in the way of the plates when mounted...after you install the plates and the struts, snugged up some, and the car on the ground, grab the top of the strut and re-align the center with your match-marks front and side...you can tug the strut right around to locate it....then snug down the CC mounting bolts...you be damn close to mint...mine's been 4 yrs and its never been in for an alignment yet....
Be prepared for the strut nut up top...that CAN be a mother if it chooses to be..If you dont have air, then a washer the same width of the slot is useful...hold it in with Vise-Grips while you loosen the nut....a hardened washer is best...to soft and it'll bend like butter....
95Vert
1,785
Apr 7, 2005
  • Apr 7, 2005
Thanks man, but believe or not, I couldn't figure out how to install the cc plates, so I didn't. Well, last night I had one of those "I can't sleep" nights and I think I figured out how they go but I'm not sure. Would you mind posting some pics?
Thanks
PS, bought used cc plates so I had no instructions. Oh and the strut nut WAS a bitch. I had to unscrew the plate and take it out all together. Then took the strut to the muffler shop and had to cut the nuts off.
RIO5.0
6,892
N.H.
Apr 7, 2005
  • Apr 7, 2005
Sent you a PM with some instructions I had from mine...
FWIW...Here's a mounted pic of each side...Good luck...
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
