a quick couple of questions
94_5.0
337
Jacksonville, NC
Every time I hit a bump my front chasis squeaks and also every time my front passenger side tire stats to rotate it squeaks as well. What could be causing these problems? I have allready replaced the tie rods so I know it is not that, any advice would be greatly apprecated, as allways thanks in advance for all of the help.
I was having similar problems because I think my grandpa must have run something over before i got the car. And the noise seemed to have something to do with bad bushings or tie rod ends possibly. But when I switched the kyb GR-2 front struts the noise suprisingly went away. So you may try that first since it is something these cars can all use anyway.
