a quick question....
MI95Cobra
451
Oklahoma City
i got my brakes replaced about 1 months ago and shortly after that whenever i come to a stop and take off or speed up from a turn i would feel and hear a popping noise from my rear...at first i thought it might be my brake callibers locking up after being changed and took them back and had them rechecked and it was a negative on that....then i thought it might be my u-joints, but again wrong(even though i went ahead and changed them), i have replaced my rear control arms(upper and lower) and made sure the bolts were still tight.....and even the shockes....still making the sound...a friend suggested that when i changed the upper control arm i should of replaced the bushings also, but when i looked under the car they still looked ok....any other suggestions or should i replace the bushings anyway???
Many of the possibilities can easily be checked. If you turn the drive shaft back and forth, by hand, you will be able to see any play in the u-joints.
Take a pry bar or large screwdriver and pry on the upper and lower control arms in such a way to see the bushings (4 of them) flex. If one is really east to flex or cracks when yo pry on it then it is bad.
Also ensure nothing is loose in the spare tire well. A can or wrench can make a nice bit of noise when you accelerate.
what do the anti rattle clips look like???
They are metal clips that snap on the ears of the rear pads, they are sometimes a PITA to reinstall and Ive seen guys get frustrated and leave them off in which case the pad could rattle or cause a clunking noise or squeal. Just thought you might check those since the noise seems to coincide with recent brake work.
