a slight lean on the driver side
  • Thread starter Thread starter red65stang
  • Start date Start date Jun 28, 2005
red65stang
28
Hartwell, GA
Jun 28, 2005
  • Jun 28, 2005
ok, for some reason my 65 leans on the front driverside. I mean when i park it on flat ground and look at it dead on the front it leans on the driverside. is it a bad spring?
G
Gud T.B. Blown
583
Jun 28, 2005
  • Jun 28, 2005
how long have you had the car? has it always had the lean and how much is the difference left to right?
red65stang
28
Hartwell, GA
Jun 28, 2005
  • Jun 28, 2005
well ive had the car since march, and it has had it ever since i got it. its a real noticible lean, like a really really heavy person would be driving it or something and im just not that heavy. but what gets me is that the wheel doesent look like its any closer to the fender on the driverside then on the passengerside.
G
Gud T.B. Blown
583
Jun 29, 2005
  • Jun 29, 2005
does it only lean when you are in it?
if the tire to fender height is the same on both sides and the car is uneven i would check for frame damage underneath.
any chassis guys out there for a second opinion?
A
a.vannoy
90
  • Jun 29, 2005
Bad shock?
cardude
221
Portland, OR
Jun 29, 2005
  • Jun 29, 2005
if its the original coils and there was a heavy person drving for a long time it may be weak spring / shock. I would also lean towards getting the frame / unibody checked to see if it is running true.
red65stang
28
Hartwell, GA
Jun 29, 2005
  • Jun 29, 2005
ahhh dont tell me its the frame
shotsy
233
Oklahoma City
Jun 29, 2005
  • Jun 29, 2005
measure the distance between the front coils on the left and right side and then compare, I'd bet that the side with the dip is just a bit weaker than the side that sits high. good excuse to do the shelby drop and get yourself a new set of coils! If the car has'nt been wrecked I would worry to much about the frame being out of whack.
stangjunkie
381
  • Jun 29, 2005
my dad had the same thing in his cobra replica.... i think we fixed it with slim-fast... drink up
notny41
204
Minnesota
Jun 29, 2005
#10
  • Jun 29, 2005
  • #10
my guess would be coil spring getting tired.
Throw a new set on - they are only about $55 and you can borrow a spring compressor at your local Autozone for free.
Might as well do the shocks too - they are even cheaper.
P
blk 02
57
Shreveport, La
Jun 29, 2005
#11
  • Jun 29, 2005
  • #11
I would try replacing the shocks first. I've seen it first hand. My boss showed me up, I told him "no way will that fix the lean the car has". sure enough he was right and I had to pay for lunch that day....
Graham
2nd Mustang
2,488
Southern California
Jun 29, 2005
#12
  • Jun 29, 2005
  • #12
My left rear sits a little lower than the right rear, especially after I sit in it, so I think it's the rear springs. Does that mean that I need to lose weight in the rear!
I really doubt if shocks are the problem. Shocks are meant to control rebound, not ride height, unless maybe someone was talking about McPherson struts, or air shocks or coil over shocks. My son's shocks were dead, but ride height was still the same, just a real loud clunking sound when hitting a bump.
blk 02
57
Shreveport, La
Jun 30, 2005
#13
  • Jun 30, 2005
  • #13
double post
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 4:43 AM
manicmechanic007
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
