A- Trim
  • Thread starter Thread starter GMdestroyer
  • Start date Start date Feb 27, 2004
G
GMdestroyer
149
  • Feb 27, 2004
I have a 88 gt and I just bought an a trim for it from a freind for only $ 500. He moved up to a procharger. What would my car run in the 1/4 on Dr supposeing i had all the things I needed to run it like mass air conversion and fuel system. Other mods in sig. 410's also just installed last week
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 27, 2004
  • Feb 27, 2004
Just a guess...but I would say maybe a mid 13 or tad better
Bone Racing
1,075
Long Island, NY
Feb 27, 2004
  • Feb 27, 2004
mid 13 or a touch better is correct...nice price
i woulda said just get the S....but thats a good price IF its in good condition
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Feb 27, 2004
  • Feb 27, 2004
You could buy that and get it upgraded to a S-trim still cheaper than a new SC-Trim cost. Id say go for it man.
Dave
rock4451
20+ Year Stangneter
Nov 30, 2004
12
New Baden, IL
Jan 2, 2007
  • Jan 2, 2007
if i were to put an a-trim(with a normal pulley) with my current setup (sig) how many horses would i pick up and ft lbs? thanks
71swing
199
Omaha,NE
Jan 3, 2007
  • Jan 3, 2007
I ran a SC-trim on a stock 5.0 two summers ago, With the smaller pulley you could get 8lbs of boost and maybe get close to the 12's like real low 13's.
than with a few more mods and pactice you could get into the 12's
With a all stock motor and the sc-trim at 5lbs I only ran a best of 13.9
snoboardcore
276
New Hampshire
Jan 3, 2007
  • Jan 3, 2007
the a-trim is an entry level blower its not made to make high boost. I think they make like 5-6#'s of boost maybe more if you can put a diff pulley on it. Even so if you put an a-trim on i dont know how well the flow numbers are on them. So i dont see more than 300 and maybe 325-350 at the the wheels if you have heads,cam and an intake.
txstang84
1,639
42
69
Tuscola, tx
Jan 3, 2007
  • Jan 3, 2007
The A trim like mentioned was an entry level, and you could squeeze almost 10 out of it with a good intake pipe and smaller pulley, but you'd be spinning the snot out of it (read high heat). Not a bad place to start, and also, already mentioned is if you turn it back to Vortech in good condition, you get $750 credit toward a new head unit...like an S trim-boost is fun!
edit: alledgedly, they'll push enough air to support up to 450hp...not sure if I buy that or not.
F
frcefedlx
184
  • Jan 3, 2007
I had an A-trim on my 93 with trick flow top end and upr power pipe seeing 5psi with a 7" crank pulley and made 393 rwhp on dynojet and for a little reference my buddies 03 cobra made 412 on same dyno with cat bacl and cold air kit on it. The A-trim does not get much credit, sure an S-trim would be better but the A-trim will make power. I believe I could have changed the pullie and ran 8 psi through it but I was pretty happy with what I had mainly because my wife wasn't.
txstang84
1,639
42
69
Tuscola, tx
Jan 3, 2007
#10
  • Jan 3, 2007
  • #10
frcefedlx said:
...but I was pretty happy with what I had mainly because my wife wasn't.
sweet
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
