Mr. G
Life is too short for all this grief and frustration
We have talked about this stuff in the tech, talk, and believe it or not, the tuning forum as well.
I know it has been in a general all around kind of discussion
but you gotta see it like this ..........
None of the Tweecer users can give 100% specific details as each situation can be a little ... or ... a lot different.
HOWEVER
We can certainly point you in the right direction
I do remember offering to help and I feel I can say other 94-95 :SNSign: Tweecer users will try as well.
After all ... thats what we do Here
... Correct
I can tell you to look at these areas for help with what you seek
tb airflow
neutral idle airflow
maf transfer idle points ... maybe 1 point above/below also
inj values such as slopes & offsets
Remember when we talked about looking at the K's to see if the adaptive is adding or pulling fuel
What do you think about this idea
Talk to us for more info ... if needed ... before starting
then
Try some of the above stuff
then
Talk to us about your results
You got everything you need
FOX PCM
We don't need no stinkin FOX PCM
Grady
