? About DSS Blocks
  • Thread starter Thread starter Deleted member 87397
  • Start date Start date Jul 18, 2007
D
Jul 18, 2007
  • Jul 18, 2007
Are their level 10/20 blocks just stock Ford blocks that they've gone through really good and made improvements to or are they some type of aftermarket block. And I'm not talking about the DART or BOSS options they offer. I want to build my first engine and I'm looking to do a 331 and I figure once I blow it up I'll have Rick91 or somebody build me a serious DART one, but for my first build I'd like a short block that can handle at least 550 or so.
9
93lxdm78
71
  • Jul 18, 2007
Good luck getting ahold of them I called them three times to get a block and they always say they are going to call back and never do. I know that there engines are very good though.
smallstang393
75
  • Jul 18, 2007
There engines are good but a stock block with sugar on top all in all is still a stock block in the end. If you want 550 better save your money and buy a aftermarket block so you don't waste it later
there products are very nice but in the end you can do what ya want but it's still stock in the end
D
Jul 18, 2007
  • Jul 18, 2007
thanks for the replies guys. For my first build I was thinking it would be putting out 350-375 NA at the crank and then I'd slap on a 150 shot or a mild supercharger to put it around 500. Mainly I want to build my first and if I screw something up I'd rather kill a 600 dollar block than a 2000 dollar one. I doubt I'll screw up, but my first shot a it will not be my all out high dollar build.
Sicarius428
2,085
Jul 18, 2007
  • Jul 18, 2007
It's just a stock block given a once over. If the money permits I would just do it right the first time. Rebuying stuff absolutely kills your bank account. The chances of when the block failing and taking something else out at the same time is pretty good too if and when it does go...
Kevin
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 18, 2007
  • Jul 18, 2007
Practically stock blocks is what DSS offers...
I believe they grind away block 'flash' to get rid of stress risers which increases the rigidity and integrity of the stock block. It is a very minute difference though...
If not already done you can have any sharp edges deburred which removes sharp edges, notches, ect.. These sharp edges, as stated, are stress risers and can initiate cracks.
They produce good affordable engines though...
ShortThrow50
923
Pa
Jul 18, 2007
  • Jul 18, 2007
fastfox86 said:
For my first build I was thinking it would be putting out 350-375 NA at the crank .
Those sound like horrible numbers on a 331 stroker. You can get that on a stock 302 block. . Do it right the first time and go for a higher compression.
D
Jul 18, 2007
  • Jul 18, 2007
Well I was just throwing out arbitrary numbers. It could be higher but you get the point of my post.
ShortThrow50
923
Pa
Jul 19, 2007
  • Jul 19, 2007
indeed
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Help with Engine Build
  • 93gtmustang
  • Nov 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2024
AeroCoupe
